charley420 Posted January 16, 2013 Share Posted January 16, 2013 Right im building the eduard/kp su25 as you can see im using the splendid set of eduard pylons for the frogfoot for the inboard pylon they offer the option of a big long pylon adapter. is it for the drop tanks or is it a launch rail for a missile? Next question are there any alternatives to the pitiful kp droptanks included with the kit? for example did the su25 ever use those tanks used by the mig 21 cheers Tom Link to comment Share on other sites More sharing options...
upnorth Posted January 16, 2013 Share Posted January 16, 2013 The rail definitely isn't for the fuel tanks, they connected directly to the pylon: The rail looks like the one used for the Kh-58 missile, though I've never seen a picture of an Su-25 toting a Kh-58: As for the Fuel Tanks, I'm not sure where You'd get 1/48 ones. However, I think the Su-25 used the same tanks as the Su-22 did. Link to comment Share on other sites More sharing options...
exdraken Posted January 16, 2013 Share Posted January 16, 2013 Hello, they seem to be for the KH-58 as updorth already said. here is a picture of a Peruian Frogfoot double seater with this weapon and pylon. http://forums.eagle.ru/showthread.php?t=21719&langid=2 hope this helps! Regards, exdaken Link to comment Share on other sites More sharing options...
charley420 Posted January 16, 2013 Author Share Posted January 16, 2013 ah ha cheers guys, so ill be needing those when I get around to building the two seater then. I think I might end up loading it up with rocket pods and maybe some aphids on the outer pylons as I really don't want to use those nasty tanks Link to comment Share on other sites More sharing options...
harvy5 Posted February 15, 2013 Share Posted February 15, 2013 Su-25 pylons for Kh-29L and CH-58. Ch-58 can carry but only upgraded Su-25UB with VJUGA system VJUGA pod Link to comment Share on other sites More sharing options...
