Orso Posted December 22, 2012 Share Posted December 22, 2012 (edited) I found out that if I woul lay the cuts in the fuselage right, I could build a DC-9-20 and a DC-9-50 from two Airfix DC-9-30 kits But what good is planning if you don't follow it. When I brought out the almost finished fuselages I realised that I forgot to remove one window in front of the wing on the shorter plane. But as it is I am not to sad as the fuselage joint between the right an left fuselage halves is to weak so they split. Now I had a chance to reinforce them. But this is typically me. Don't think to much just bring the saw out and get to work. Redo it right later. But I get more building time for the money this way. Well now I have cut the fuselage apart, removed the extra window, reinforced the weak joints, and glued it all back together. When I've puttied the joints once again I'm back at square one. Edited October 13, 2018 by Orso Photobucket sabotage Link to comment Share on other sites More sharing options...
wellzy Posted December 24, 2012 Share Posted December 24, 2012 Hi Bjorn good luck with this and welcome to the Group Build Les Link to comment Share on other sites More sharing options...
Orso Posted December 26, 2012 Author Share Posted December 26, 2012 (edited) OK. So I repaired the mistake I Did when shortening the kit. Lets get on with the build. Edited October 13, 2018 by Orso Photobucket sabotage Link to comment Share on other sites More sharing options...
cuprar Posted December 26, 2012 Share Posted December 26, 2012 Great work! Link to comment Share on other sites More sharing options...
