Dads203 Posted December 12, 2012 Author Share Posted December 12, 2012 I'm still watching. Have you tried rolling Kleenex soaked in PVA and tying thread around it? works quite well. Bugger to light though Nick You just have to be a bit careful what you put in it Link to comment Share on other sites More sharing options...
Mike Posted December 12, 2012 Share Posted December 12, 2012 Link to comment Share on other sites More sharing options...
Panzer Vor!!! Posted December 12, 2012 Share Posted December 12, 2012 You just have to be a bit careful what you put in it Link to comment Share on other sites More sharing options...
Dads203 Posted December 12, 2012 Author Share Posted December 12, 2012 Right, getting back to the build, more PE work tonight, mostly on small fittings like the unditching log top brackets, APU exhaust shroud and the turret stowage box handlesand I've still got more to go One more of the tarp I made, still not sure if i'll use it yet? Might have another go at it. Cheers Dan 1 Link to comment Share on other sites More sharing options...
Mike Posted December 12, 2012 Share Posted December 12, 2012 Give it a squirt of primer... that should decide you one way or the other Link to comment Share on other sites More sharing options...
Dads203 Posted December 12, 2012 Author Share Posted December 12, 2012 Think you are right Mike, I've added the tie down straps and I'll give it a blast with some primer. Cheers Link to comment Share on other sites More sharing options...
Dads203 Posted December 12, 2012 Author Share Posted December 12, 2012 And fitted to the turret. Looks better with the straps added. Dan 1 Link to comment Share on other sites More sharing options...
Mike Posted December 12, 2012 Share Posted December 12, 2012 Yeah... I'd use it if it were my T-64 Link to comment Share on other sites More sharing options...
Dads203 Posted December 12, 2012 Author Share Posted December 12, 2012 I think i will Mike, just finished adding the last of the PE parts, only a few plastic parts left to add. I'm thinking of adding the commanders ang the gunners sight units as they are quite visible through the Open hatches, anyone have any pictures of the units that would help? Dan Link to comment Share on other sites More sharing options...
Dads203 Posted December 13, 2012 Author Share Posted December 13, 2012 Spent an hour working on the commanders TKN-3MBU sight unit/ periscope, made from scraps of resin and plastic stock. still a bit more to add and its only a representation that can be seen through the hatch. Two handles need to be added, one each side. I'll make them from a scrap of PE. The big block on the back won't be seen and its handy to use to hold it with. Cheers Dan 1 Link to comment Share on other sites More sharing options...
Dads203 Posted December 13, 2012 Author Share Posted December 13, 2012 (edited) And now finished, close enough for government work I think Just need some ref pix of the Gunners main sight for the other hatch. Dan Edited December 13, 2012 by Dads203 Link to comment Share on other sites More sharing options...
Dads203 Posted December 14, 2012 Author Share Posted December 14, 2012 The last few bits being added and worked on, The Gill side plates and the recovery ropes, the cable is not in the kit but the ends are? No mention on the instructions but the A model carried them. Brass wire is picture hanging wire. Cheers Dan Link to comment Share on other sites More sharing options...
Dads203 Posted December 14, 2012 Author Share Posted December 14, 2012 Some pix of the underside, added a loop to the dozer blade that was missing from the kit, just fine brass wire and a couple of small holes. And the unditching log straps with the rubber log.... Cheers Dan Link to comment Share on other sites More sharing options...
Mike Posted December 14, 2012 Share Posted December 14, 2012 A rubber log, eh? You'll be telling us next that it came with the kit Looking good though Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 Should be in for paint today, normal routine with primer going on first and then The green top colour, anyone like to suggest the best match for Russian green? Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 Primer on Lets start painting ! Wheels and gun barrel are done, next is the tracks black primer I think for those. Dan Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 Pre shade done Dan Link to comment Share on other sites More sharing options...
Mike Posted December 15, 2012 Share Posted December 15, 2012 Base coat on by Monday - there's a jolly good chance it'll be in the cabinet by the end of the year... Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 It's looking that way Mike, just Alclading a few bits that will get chipped and Prime the tracks next. Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 (edited) Here are the two areas that will get some paint wear, Firstly the APU box, I think that this was made from Alloy rather than steel, most of my ref pix show this with bad paint wear an no rust. And the turret bins, these again are made from some alloy. Please feel free to pass comment. Dan Edited December 15, 2012 by Dads203 Link to comment Share on other sites More sharing options...
smuts Posted December 15, 2012 Share Posted December 15, 2012 Hi Dan, great work had to order one for myself does look a step up from the ERA as well.. hope this helps I used Tamiya olive green on my BTR, looks a good match to the cold war green used by the red army gettin the itch to start the ERA now.... Andy. Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 (edited) Nice BTR Andy looks the part fella, is that XF58 that you used? Edited December 15, 2012 by Dads203 Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 Right, this is where I'm at now, XF58 Olive green used as the base colour and lightened with XF49 Khaki, almost like a colour modulation. looks better in the flesh as my lighting and camera are not the best. The turret bins are now green, i've used maskol mask areas I want to chip, i'll wait for the paint to fully cure before removing. Regards Dan Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 Couldn't wait to see the effect, it's turned out good, better in natural light. Cheers Dan Link to comment Share on other sites More sharing options...
Dads203 Posted December 15, 2012 Author Share Posted December 15, 2012 And a last few pictures as I'm knocking off for the night. Cheers and have a good weekend Dan Link to comment Share on other sites More sharing options...
