smuts Posted December 1, 2012 Share Posted December 1, 2012 Hi, nice work, looks a nice kit too.. Andy. Link to comment Share on other sites More sharing options...
pabbi Posted December 1, 2012 Share Posted December 1, 2012 great detail work Link to comment Share on other sites More sharing options...
stoohoo Posted December 1, 2012 Author Share Posted December 1, 2012 Thanks Andy and Pabbi, its a nicely detailed kit for the price, though from the looks of it the Zvezda one has more detail out of the box. The fuselage dry fit looks a little bad, but that could just be being spoilt with my last 2 builds (Hasegawa Spit mk XVI and Hobbyboss TA152) which were beautifully fitting kits. Cheers again, Stu Link to comment Share on other sites More sharing options...
stoohoo Posted December 11, 2012 Author Share Posted December 11, 2012 Bit more of an update - just realised its about halfway through the group build and i'm only just getting close to sticking the fuselage halves together!!!! Well since last time i have stuck all the pit together And painted and matted it down Also painted and added the fual line to the RHS pit wall and matted down stuck the etch IP together and built up with the gunsight, minus the glazing for now and got on with a few other small bits - etch gear covers and added a filler nozzle and cap to the tank on the side of the engine thats going to be visible and hollowed out one set of exhaust Now if i can just sneak it all into work and get away with building it on the sly Cheers, Stu Link to comment Share on other sites More sharing options...
Phil Podmore Posted December 12, 2012 Share Posted December 12, 2012 Sorry to be the bearer of bad news, but your rudder pedals are on upside-down.... 1 Link to comment Share on other sites More sharing options...
FalkeEins Posted December 12, 2012 Share Posted December 12, 2012 (edited) ....you are doing some neat work.... Edited December 12, 2012 by FalkeEins Link to comment Share on other sites More sharing options...
pabbi Posted December 12, 2012 Share Posted December 12, 2012 The pit looks super nice ! Link to comment Share on other sites More sharing options...
stoohoo Posted December 13, 2012 Author Share Posted December 13, 2012 Thanks for the kind comments guys and for the heds up Phil - you wouldnt belive thats the second luft aircraft in a row that i have managed to do that on... Luckily i was able to pry the pit off the fuse side i had glued it to and switch them over without destroying them completely, heres the pic for proof before they dissappear within the fuse forever Cheers all Link to comment Share on other sites More sharing options...
Spikelhund Posted December 14, 2012 Share Posted December 14, 2012 Looking really nice Stu, I like the cockpit painting, look forward to seeing more soon. Cheers... Link to comment Share on other sites More sharing options...
oldhouse Posted December 20, 2012 Share Posted December 20, 2012 Very nicely done so far !! Good Job !! Peter Link to comment Share on other sites More sharing options...
smuts Posted December 20, 2012 Share Posted December 20, 2012 Looking very good....nice work Andy Link to comment Share on other sites More sharing options...
Dan Posted December 20, 2012 Share Posted December 20, 2012 That's a great cockpit, the finish is incredible! Link to comment Share on other sites More sharing options...
Skybert Posted December 21, 2012 Share Posted December 21, 2012 Good job on that cockpit Stu.. Link to comment Share on other sites More sharing options...
stoohoo Posted December 22, 2012 Author Share Posted December 22, 2012 Thanks guys Progress has been a bit slow with the build up to christmas in full swing but managed to get a couple of bits off the list. First wanted to sort the spinner out, i have replaced the blast tube with some brass microtube and managed to add the missing panel line on the spinner with the aid of a drill and a sharp point - this is the first time i have tried using a drill as a lathe and fairly please with how its worked out, though want to get some paint on and see how it looks then Before: After: Also had a go at improving the tropical filter as the one in the kit is a bit lacking. I smash moulded the end on some acetate sheet and cut into 2 parts, then drilled out the kit part and added a mesh screen from some fine plastic gauze sheet and some final detail with foil tape. Not 100% sure on what i've ended up so going to see how it looks under some paint, if not its going to be resorting to the excellent looking replacement by quickboost Before: After: Thanks for looking and if i dont post anything else before, have a great christmas! Cheers, Stu Link to comment Share on other sites More sharing options...
trickyrich Posted December 22, 2012 Share Posted December 22, 2012 Nice work with the "drill/lathe", have done that before. I use a small dremal and as long as you can centre and secure the parts it works well. The tropical filter looks ok, a nice coat of paint and some shading will do wonders for it. This is coming along very nicely. Link to comment Share on other sites More sharing options...
stoohoo Posted December 29, 2012 Author Share Posted December 29, 2012 Cheers Rich, Modelling times been a bit sparse over christmas, not necessarily a bad thing but progress has been slow, finally got enough to post a couple of pics though. First off completed detailing the inside of the open cowl, this was done with stretched sprue and foil tape to try to recreate the internal ribbing. Before shot: After: Also got a bit more done on the motor: Not finished yet but hopefully once this and the engine bay are completed and together it will break the back of the fiddly stuff and i might stand a chance of finishing in time! Cheers for looking, Stu Link to comment Share on other sites More sharing options...
Kahunaminor Posted January 3, 2013 Share Posted January 3, 2013 Stu, The innards are a treat. Well done. Link to comment Share on other sites More sharing options...
stoohoo Posted January 3, 2013 Author Share Posted January 3, 2013 Cheers Kent Well one more pic to show at last, have finished adding the detail to the engine bay and assembling it all and now ready for a coat of matt and putting together the rest of the cowl, hoping that it all lines up! The basic block is quite nicely detailed but the firewall was bare so have added a lower shelf and a couple of bits that i have seen in reference pics posisbily not completely accurate but does busy it up a bit! Also added some hoses and bits from solder masking tape and foil tape, not done a lot of scratch building to date so its a bit clunky but doesnt look too bad at 1:1 scale Anyway, enough waffling and on with the pic Cheers for looking, Stu Link to comment Share on other sites More sharing options...
stoohoo Posted January 16, 2013 Author Share Posted January 16, 2013 Hi all,  Update time again, cant believe how much time has passed by and how little progress I have made, I hadn’t realised just how time consuming adding a full etch set would be and combined with keeping the engine exposed I think I might now struggle to get there by the deadline…still will keep plugging on and see where we get.  So progress up til last night is as follows:  After much dry fitting and tweaking and eventually shaving a fair bit off the RHS engine bearer I have got the cowl to all fit on pretty neatly, then the top and bottom fuse seams have been sanded considerably and rescribed. The bottom seam was a PITA as there is kind of a combination lip and sink mark that runs the full length so this took a bit of work to remove, the plastic is nice though and sands and glues very well. Top half of the wings have been attached to make the root joint a bit easier. Had the bright idea of getting some of the front end colour on before assembling hoping to make masking around the exhausts a bit easier but retrospectively it was probably just time wasted   The spinner has been painted and the prop given a bit of chipping, though cant decide if it’s a bit overdone. I had a spare polycap from a recent build and that fitted nicely in the spinner so can push fit it on at the end and take it off if it needs a bit more work   Got the etch gear covers painted as well as the gear legs. The brake lines are a combination of the etch parts and some fine solder for the coiled hose. Also added the etch parts you get for the backs of the wheels   Finally I have been getting together the etch replacements for the radiators and flaps, the flaps themselves were a bit of a fun job to get together as they are very delicate and I was struggling in places to keep the carpet (or laminate floor) monster at bay but managed to do it all without losing anything in the end.  Pic of the flaps   And of the lower wing with the various bits to be fitted, think these will need painting first to make life a bit easier   And that’s it so far, hope to get the lower wings sorted and some primer on soon…  Cheers for looking, Stu Link to comment Share on other sites More sharing options...
AndyC Posted January 16, 2013 Share Posted January 16, 2013 Very impressive work my friend! Â This will be some work of art when its done! Link to comment Share on other sites More sharing options...
Phil Podmore Posted January 16, 2013 Share Posted January 16, 2013 The flaps are a killer arent they, I did those on my 109K and swore all the way through! Link to comment Share on other sites More sharing options...
Carts Posted January 16, 2013 Share Posted January 16, 2013 Some impressive detailed work on show here,look forward to seeing more. Link to comment Share on other sites More sharing options...
Killa Posted January 16, 2013 Share Posted January 16, 2013 Very nice work on the bird! Â Â Could you please post a picture or item number of the PE set? Â Â Cheers. Link to comment Share on other sites More sharing options...
stoohoo Posted January 17, 2013 Author Share Posted January 17, 2013 Thanks for the kind comments guys   The flaps are a killer arent they, I did those on my 109K and swore all the way through!  Cheers Phil, yes i had been kind of dreading them since i got the set and kept putting them off, waiting to see how solid they are when i get them on the model as they only attach via part of the little linkage at the rear, will have to superglue and cross my fingers...   Very nice work on the bird!   Could you please post a picture or item number of the PE set?   Cheers.  Cheers Killa, not got a piccie of the set to hand but its eduard part number ED49346 (i got it from hannants). It says its for the F-2 but as far as im aware its accurate for an F-4 as well. Theres 3 frets and a lot of bits in it so hours of fun to be had trying to fit it all  Cheers again all, Stu Link to comment Share on other sites More sharing options...
stoohoo Posted January 31, 2013 Author Share Posted January 31, 2013 (edited) Well my prayers have been answered...another week, got no excuse not to get this one done now! Time for a bit of a progress update.... Got the seperated cowl panel complete (well bar possibly a bit of exhaust staining at the lower edge) kind of rushed this bit through as i was impatient to see how the scratch built bits on the air filter and inside of the cowl were going to look once done, also to see how the decals performed (they are great). Got to say i'm pretty happy with the result, at least it was worth the time spent messing around. Wheels are now complete so thats the landing gear ready to fit when i get to it, the tyre black is a bit close in colour to the hub so will see how it looks under a matt coat. Finally got the last main colour on last night, i used xtracrylics for the RLM04 and RLM78 and they look pretty good from the bottle. I went with humbrol 118 us tan for the RLM 79 as i had that in the paint box already and it looks a pretty good match to me. So then finally after a few days of mounting impatience i was able to take off the ever increasing layers of masking tape and see what lies beneath.... Hasnt come out too bad, had a bit of a worried moment on the underside where i hadnt masked far enough back when doing the wrap around on the leading edge and had oversprayed onto the blue but fortunately a bit of warm water and scotchbrite saved the day. Also got the flaps sprayed up and couldnt resist fitting to see how they look, though i can see it being refitted by the end of the build - this is definately going to be too delicate for the kids to fly around the house So thats where we are as of 11:30 last night. Big thanks to Andy and Mish for the extra week Cheers for looking, Stu Edited January 31, 2013 by stoohoo Link to comment Share on other sites More sharing options...
