DaveJL Posted August 21, 2012 Author Share Posted August 21, 2012 Brief start made this afternoon. Cockpit built up and painted: The Pavla set was great, went together in no time. After that dried, it was installed to the front fuselage: Main fuselage section assembled: Also built up all the ordnance; 2x AIM-9, 2x Paveway II, 2x BL755 and a TIALD pod: Not much, but it's a start! Dave 1 Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted August 21, 2012 Share Posted August 21, 2012 As you say, it's a start. With all them goodies it should be a great build. Link to comment Share on other sites More sharing options...
DaveJL Posted August 21, 2012 Author Share Posted August 21, 2012 Thanks Mish. My B-1B is nearing completion so will be full steam ahead with this and hopefully my B-17G if i can sort out the sprue 'issue' i'm having! Cheers Dave Link to comment Share on other sites More sharing options...
DaveJL Posted August 26, 2012 Author Share Posted August 26, 2012 (edited) A bit more to show today. The nose section has been added, as have the intakes: Tail and various other parts attached: I had then intended to attach the wings and LERX but ran into a problem. Here are the parts dry fitted: There is quite a 'step' between the edge of the wing and the LERX. When i corrected that to the same level, the join at the edge of the LERX/wing became a gap and vice versa. Any hints on how to get this right without having to do a tonne of sanding? Along with the fit problem, i managed to crack the LERX and take a chip out of it!! Also, am I right in saying the two vents on the upper side of the LERX are only on the GR.9? More to come. Dave Edited August 26, 2012 by DaveJL Link to comment Share on other sites More sharing options...
SaintsPhil Posted August 26, 2012 Share Posted August 26, 2012 Nice work do far Dave despite the damage! Have you tried fitting the lower wings to fuselage then top wings to LERX and fitting that assembly? Should move any joints to wing leading edges, much easier to clean up. Failing that you'll probably have to trim LERX before you fit it all. Yes the 'frog eye' fire access scoops are for GR9, as additional wiring runs down leading edge, blocking old fire access points. Link to comment Share on other sites More sharing options...
DaveJL Posted August 26, 2012 Author Share Posted August 26, 2012 Didn't think of that Phil, i'd already glued the wings together I'll give it a go. Thanks for the info. The scoops need to come off then. Cheers Dave Link to comment Share on other sites More sharing options...
SaintsPhil Posted August 26, 2012 Share Posted August 26, 2012 Actually Dave don't whip them off just yet I'll double check the info on the Harrier Sig, I may have mislead you...can't remember if 100% LERX aircraft had them all along... Link to comment Share on other sites More sharing options...
DaveJL Posted August 26, 2012 Author Share Posted August 26, 2012 Actually Dave don't whip them off just yet I'll double check the info on the Harrier Sig, I may have mislead you...can't remember if 100% LERX aircraft had them all along... Thanks Phil. The pictures i have as reference don't seem to show them. Thanks Phil. The pictures i have as reference don't seem to show them. Correction, they do! Link to comment Share on other sites More sharing options...
SaintsPhil Posted August 26, 2012 Share Posted August 26, 2012 Sorry Dave, leave them on!! 100% LERX had them all along! Link to comment Share on other sites More sharing options...
DaveJL Posted August 26, 2012 Author Share Posted August 26, 2012 Sorry Dave, leave them on!! 100% LERX had them all along! Glad we both checked mate Dave Link to comment Share on other sites More sharing options...
SaintsPhil Posted August 26, 2012 Share Posted August 26, 2012 Good job you waited, I've have whipped them off and binned them by now... Link to comment Share on other sites More sharing options...
delta7 Posted August 26, 2012 Share Posted August 26, 2012 (edited) this is a tricky kit with the lerx wing join, here are two ways of doing it that helped me http://hsfeatures.co...iergr7pds_1.htm http://www.zone-five...read.php?t=3428 hope this helps Edited August 26, 2012 by delta7 Link to comment Share on other sites More sharing options...
DaveJL Posted August 26, 2012 Author Share Posted August 26, 2012 Thanks for the links. I'll have a play about and see what I can do. Dave Link to comment Share on other sites More sharing options...
SaintsPhil Posted August 28, 2012 Share Posted August 28, 2012 Here's another build worth looking at, it's an AV8B but the main theory is the same http://www.scalespot.com/onthebench/av8bna/av8bna_build.htm Link to comment Share on other sites More sharing options...
DaveJL Posted August 28, 2012 Author Share Posted August 28, 2012 Thanks Phil, great build in that link. I have an idea of how to tackle the LERX (or LEX, whichever it is!!) Will post some photos tomorrow. Dave Link to comment Share on other sites More sharing options...
DaveJL Posted August 29, 2012 Author Share Posted August 29, 2012 Ok, more to show, well, a little more anyway! The fit of the LERX was doing my head in, so I pulled it all apart (and managed to crack a wing in the process - this build is cursed!) and started again. I glued the bottom half of the wings to the fuselage, which I should have done to start with as that's what the instructions say! Once dry, I added the LERX, Still wasn't a great fit, so I trimmed some of the forward edge then glued it down. Once set, on went the top halves of the wings: The rear sections of the wings would not sit flush with the fuselage so hence the heavy duty 'clamps'. Once it had set, i had to fix the join lines, which were no where near as pronounced as when i dry fitted a few days ago, but still in need of filler none the less. This is where we are at close of play today: Pain in the a***!! Note the panel behind the cockpit has also been added. I had to trim this as well to get a flush join. Next up is to sand off the mess i've made!! More to come. Dave 1 Link to comment Share on other sites More sharing options...
SaintsPhil Posted August 29, 2012 Share Posted August 29, 2012 You're not having much luck there! I had similar issues with the first one I built but not quite like yours! Link to comment Share on other sites More sharing options...
DaveJL Posted August 29, 2012 Author Share Posted August 29, 2012 You're not having much luck there! I had similar issues with the first one I built but not quite like yours! I know mate I don't know what's going on!! I thought this would be a doddle after the 1/48 B-1, but alas, no We'll get there in the end....hopefully Dave Link to comment Share on other sites More sharing options...
AnonymousDFB1 Posted August 29, 2012 Share Posted August 29, 2012 Keep at it Dave, it'll be worth it. Link to comment Share on other sites More sharing options...
DaveJL Posted August 29, 2012 Author Share Posted August 29, 2012 Keep at it Dave, it'll be worth it. Touch wood, the worst is over I never abandon a project, no matter how trying it is! Dave Link to comment Share on other sites More sharing options...
wellzy Posted August 30, 2012 Share Posted August 30, 2012 Good man never give up , Les Link to comment Share on other sites More sharing options...
DaveJL Posted August 30, 2012 Author Share Posted August 30, 2012 Good man never give up , Les With the amount i've spent on this there's no chance of that Dave Link to comment Share on other sites More sharing options...
DaveJL Posted September 2, 2012 Author Share Posted September 2, 2012 Well I stuck with it and I'm happy to report that it's cleaned up well! Spent about an hour just cleaning up the mess I'd made of the LERX area then started to add bits and pieces, starting with the wing tips then moving on to the horizontal stabilisers and pylons. Also added the gun pod and TIALD pylon. Does anyone know if the centre line pylon was also carried? Just needs a tidy up here and there then i'll paint the IP coaming, attach and mask the windshield and start the painting! More to come. Dave Link to comment Share on other sites More sharing options...
SaintsPhil Posted September 2, 2012 Share Posted September 2, 2012 Good work Dave, I'm pretty sure they did carry the centre pylon, some jets 'borrowed' Vicon recon pods from the Jag fleet and flew with those on centre line pylon. Phil Link to comment Share on other sites More sharing options...
DaveJL Posted September 2, 2012 Author Share Posted September 2, 2012 Thanks Phil. Good work Dave, I'm pretty sure they did carry the centre pylon, some jets 'borrowed' Vicon recon pods from the Jag fleet and flew with those on centre line pylon. Phil Thanks Phil. I'll add the pylon before painting. Dave Link to comment Share on other sites More sharing options...
