atvd1020 Posted June 25, 2012 Share Posted June 25, 2012 (edited) While getting decals on a Sweet Macchi 200 trying to settle down with Mr. Mark Softer, the above happened. It managed to eat through Citadel gloss varnish and the Tamiya paint below it. Has anyone else had the same problem with other acrylic varnishes? Edited June 25, 2012 by atvd1020 Link to comment Share on other sites More sharing options...
colin Posted June 25, 2012 Share Posted June 25, 2012 I haven't had it happen, though I've only used mirco sol, but have heard that Mr Mark can do that. Link to comment Share on other sites More sharing options...
turnerdad Posted June 26, 2012 Share Posted June 26, 2012 Many of the decal softeners will soften the paint, and even discolour it if you apply it too heavily and allow it to sit for too long. Apply it thinly so it can evaporate within a few minutes, and you must not let it pool. While I havn't had it lift or craze paint, I have damaged it by handling these soft areas before they have fully dried out and am now exremely careful when applying any decal solution. Link to comment Share on other sites More sharing options...
christof Posted June 26, 2012 Share Posted June 26, 2012 Yep had that happen to me. I've also had Mr Mark softer cause the colours on the decal to run. It is quite hot. Went back to Microsol on acrylics. Christof Link to comment Share on other sites More sharing options...
Giorgio N Posted July 1, 2012 Share Posted July 1, 2012 It happened to me on Klear/future and some acrylic clear coats. As others have said, it's one of the strongest solutions around and must be used sparingly. I prefer to use the Microscale products for most decals and only use the Mr. Mark on some thicker decals that need something stronger than the american products. 1 Link to comment Share on other sites More sharing options...
noeyedears Posted July 1, 2012 Share Posted July 1, 2012 Yup, this is strong stuff. had it ruin tamiya decals as well as soften the clearcoat. use as little as possible and dont soak everything it it, and definately dont try to move deacals after applying it. I try to use it only on tough decals like carbon fiber from aftermarket companies as they tend to be more resilient and need to conform to odd shapes. Link to comment Share on other sites More sharing options...
tank152 Posted July 1, 2012 Share Posted July 1, 2012 (edited) Yeah it happened to me the first time I used it, but thats because I wasn't used to how strong it is. As others have already said don't let it pool and it will be fine. I very rarely use Sol nowadays, i'll now start with Daco Orange (around the same strength as Sol) and if that doesn't do the job i'll use Mr Softer failing that i'll move on to Daco Red which I reckon is one of the strongest of the softners. Edited July 1, 2012 by tank152 Link to comment Share on other sites More sharing options...
atvd1020 Posted July 2, 2012 Author Share Posted July 2, 2012 I see....I should be more careful with Mr. Mark Softer in future, especially with acrylic over acrylic. Thanks for the information. Link to comment Share on other sites More sharing options...
wbk666 Posted October 12, 2012 Share Posted October 12, 2012 wow i nearly sent off for some. is microsol the best option for use on acrylics then? Link to comment Share on other sites More sharing options...
