This is my entry for the F16 G/B ,the kit is the Academy F 16 C ,I have been told I can use this as a N (please let me know if this is wrong)plus
bits from the spares box, cockpit out of a Hasegawa F16 resin seat and wheel bay other bits will be pulled out of the spares box as I go on .
wellzy :headphones:
Edited by wellzy
I will be using towbobs 48-038 Old School Adversarys F16N sheet
wellzy :headphones:
Hi Wellzy
To do a proper F-16N, you must have a GE engine - the kit you use have only the PW engine. Visually the difference is very noticable.
If you have a Hasegawa F-16C Block 30 or 50, you will have what you need, if not there are plenty of aftermarket alternatives available.
Hi Wellzy
OK can I just change the rear can sorry if it not got a fan on it Im lost
wellzy :wall:
I believe it needs a different intake as well.
Edit: This should do. Linky Bit pricy though, especially is you need a new rear end.
Edited by Enzo Matrix
OK I give up going back to a ANG F16 C I was only going to use this kit as it was a freebee
wellzy :headphones:
The intake is correct, but the engines are different.
I've just checked. You are quite correct. The intake on F-16Ns is the small one, so Wellzy's kit is perfectly fine. It will still need the GE back end though.
So... basically the F-16N is a weird mutant! :lol: Should make an interesting model.
Ok so is that new rear can or more ?
wellzy :headphones:
Wellzy,
I just dug my Academy kit out and put the Aires F-16C Block 20/40/50/60 can (The correct one for an F-16N) against it. It is almost a perfect fit, which isn't a surprise as the Academy fuselage is identical in size to the Hasegawa one (read what you like from that, a clone maybe). The Aires F-16N cockpit would also fit without any problems if you wanted to go that far. I'll post a picture later to show how close a fit that the exhaust is.
Easily do-able from the kit you have and I'm tempted to have a bash for this group build, if I get the other 2 done in time
Pete
Thanks for all your help Pete now time to rock and roll .
wellzy :headphones:
Great start Wellzy,
As promised, picture of Aires exhaust on same kit as yours: -
With a little bit of sanding it will work perfectly. If anything it's an easier fit than on the Hasegawa.
Pete
Edited by Peter W
This should be good, I've always liked the adversary F-16's :popcorn:
Great start Wellzy,
Pete
Thanks Pete looks good
wellzy :headphones:
I'm pleased that you weren't put off doing the N. :)
So am I Enzo the decal sheet been around for a long time so it was time ,
It`s not going to bad look like it will need some filler here and there .
And we go on
wellzy :headphones:
Now this is where the fit of the Academy kit starts showing it self ,
let the fun begin.
wellzy :headphones:
I see what you mean Mish will not need nose weight in this one its going to
have a lot of filler up the nose end. the first two photo`s should have been posted
with last nights.
now for todays work
more filler !!!!!!!!!!!!!!!
wellzy :headphones:
Edited by wellzy
I got the impression when I dry fitted mine together that filler would be a good friend for the build. Perseverence pays off though Wellzy and you're making good progress.
Pete
And more filler
And there will be more
The Hasegawa canopy fits well!!
wellzy :headphones:
Edited by wellzy
Sign in to follow this
