racedees Posted April 10, 2012 Share Posted April 10, 2012 (edited) My project for this GB will be: The box Manual And a pile of plastic Metal Pitot (in the corner of the box) Clearparts and some PE. Decals: And some detail of the decals Edited April 10, 2012 by racedees Link to comment Share on other sites More sharing options...
Jasonb13 Posted April 10, 2012 Share Posted April 10, 2012 That looks nice, love the detail in the decals! Have never built Kinetic before, I hope it all goes together well for you! J. Link to comment Share on other sites More sharing options...
PanzerPaulo Posted April 10, 2012 Share Posted April 10, 2012 noooo waaaay!!! It's gonna be a beautifull build!!! Link to comment Share on other sites More sharing options...
Mike N Posted April 12, 2012 Share Posted April 12, 2012 Nice choice I'll be very interested in how you get along with this, often been tempted to buy one...! Mike Link to comment Share on other sites More sharing options...
wellzy Posted April 16, 2012 Share Posted April 16, 2012 (edited) Looks a very nice kit I will watch and see how it builds . wellzy Edited April 16, 2012 by wellzy Link to comment Share on other sites More sharing options...
Lex77 Posted April 17, 2012 Share Posted April 17, 2012 Daniël, Kinetic made some faults in this kit; - Check your references for the PE parts. Most of them are not on the Belgium F-16's. - Unlike for example the Dutch F-16's the F-16's from Belgium don't have the parachute in the tail but some kind of ECM equipment (in the box aswell) - The base of the tail has a different angle then the one in the kit. Here a description how to correct it http://ultra.glo.be/daco/KF16Kinetic.html Hope this helps! Link to comment Share on other sites More sharing options...
racedees Posted June 15, 2012 Author Share Posted June 15, 2012 Finaly had some time to build last weekend. This is the result thusfar: Pilots office glued into fuselage and fuselage halfs glued together. to be....... Link to comment Share on other sites More sharing options...
Mike V Posted June 17, 2012 Share Posted June 17, 2012 Daniël,Kinetic made some faults in this kit; - Check your references for the PE parts. Most of them are not on the Belgium F-16's. - Unlike for example the Dutch F-16's the F-16's from Belgium don't have the parachute in the tail but some kind of ECM equipment (in the box aswell) - The base of the tail has a different angle then the one in the kit. Here a description how to correct it http://ultra.glo.be/daco/KF16Kinetic.html Hope this helps! Among shape and detail inaccuracies, this kit title is all wrong as there's no such thing as an "F-16A Block 20 MLU". Block 20 is a "production" F-16A/B Airframe updated with Block 40/50 wings and modern C/D cockpit/Avionics. The basic vertical tail and dorsal is the same as other parabrake F-16A/Bs, but it has an F-16C/D tail cap. The MLU F-16A/B (AM/BM the redesignation) is a C/D conversion or upgrade, though the vertical tail remains unchanged. They are two different variants. The Belgium Parabrake housed the CARAPACE ECM system, then later the RAPPORT III System. Also note the Belgium Block 5-10 F-16s were originally delivered without the parabrake. Kinetic hosed up the F-16A/B vertical tail dorsal something fierce. It’s too wide to begin with; as wide as the C/D dorsal. The side slope and taper is also off, as depicted in the DACO correction. Combined with those hideous punch marks on the right side of the vertical tail, it's a mess to clean up. A corrected vertical tail is need for the Kinetic F-16A/B/AM/BM kits. Also note that the kit's Light Weight Gear structure detail is that of the Heavy Weight gear; yet another Kinetic oversight. Where the shock strut mounts to the tension strut, that structure should not have the two parallel channels. For a correct LWG structure, it should have the triangular channel. Well done work on a tough kit; keep it up. Link to comment Share on other sites More sharing options...
Deacon Posted June 29, 2012 Share Posted June 29, 2012 Nice, another Tiger Meet. I have the same aircraft to make up, but the Revell 1:72 boxing. Deacon Link to comment Share on other sites More sharing options...
racedees Posted July 5, 2012 Author Share Posted July 5, 2012 Did some work tonight. The air intake, horizontal stabs and some wingparts are placed. Will make some daylight pictures tomorrow . Link to comment Share on other sites More sharing options...
racedees Posted July 6, 2012 Author Share Posted July 6, 2012 Here are some daylight pics. And here a picturetogether with a 1/144 scale (Dragon) that I'm bulding with my daughter (age 7). Link to comment Share on other sites More sharing options...
Parabat Posted July 6, 2012 Share Posted July 6, 2012 Looking good, nice to see it with the Dragon 1/144 F-16 too! Link to comment Share on other sites More sharing options...
racedees Posted July 12, 2012 Author Share Posted July 12, 2012 While sanding down the moldline on the canopy it cracked on this line I will use the canopy and hope that I will get a new one somehow. I also painted some parts. Hopefully I will make it in time. Will place new pics when there is some progress. Link to comment Share on other sites More sharing options...
racedees Posted July 13, 2012 Author Share Posted July 13, 2012 The progress of yesterday..... The engine is a cold fit, still needs some work before glueing together. I also see that the left horizontal is hanging to much. Have to correct that also. and on the inside.. The cracked canopy... :shithappens: The undercariage Pilots office still without seat Coldfit with canopy and vertical (waiting for some modifications... Link to comment Share on other sites More sharing options...
racedees Posted July 15, 2012 Author Share Posted July 15, 2012 Yesterdays damage... The tail is still a dryfit becouse I damaged my tailbase while modifying it.... So I have to remodel it with putty, sanding and rescribe it. Bottomline is that I will not make it in time. Her are the results thusfar. Mind that the engine, vert. tail and those tapes "tubes" wich I think are droptanks or something, are dryfits. And now off to do some modelling again.... Link to comment Share on other sites More sharing options...
racedees Posted July 15, 2012 Author Share Posted July 15, 2012 This is how far I managed this STGB. Pity I haven't finished it in time, but I will continue this on. Main colors are on, but i have to place some clear parts and the wheels. Ad of course the decals. My "final"results for this STGB: I will show the rest of this build in the normal topics for those who are interested. Link to comment Share on other sites More sharing options...
Parabat Posted July 15, 2012 Share Posted July 15, 2012 Never mind, I never finished my FW190 on time and I'm glad I never rushed it. I'm sure this will look great when you finish it. Link to comment Share on other sites More sharing options...
racedees Posted July 16, 2012 Author Share Posted July 16, 2012 (edited) For those who are interested, I will continue this build over here. Edited July 16, 2012 by racedees Link to comment Share on other sites More sharing options...
Mike N Posted July 16, 2012 Share Posted July 16, 2012 Never mind not finishing in time, sometimes a kit fights back and has its own schedule. Far better to take your time and do it properly Will continue to follow your new thread to completion. Well done on the work so far! Mike Link to comment Share on other sites More sharing options...
