AndyL Posted April 13, 2012 Share Posted April 13, 2012 Nice job with the riveting. I don't have the patience to complete such a task, but you have shown it enhances the build, and is well worth while. Link to comment Share on other sites More sharing options...
jacksdad Posted April 13, 2012 Share Posted April 13, 2012 Nice job Marc. Good luck with the spiral. Steve Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 13, 2012 Author Share Posted April 13, 2012 Thanks Steve least of my worries at moment just primed her & noticed filler cracked after finishing rivets, Going to use Zap a gap & sand & not loose too much detail. Just noticed date FRIDAY 13TH. Link to comment Share on other sites More sharing options...
tank152 Posted April 13, 2012 Share Posted April 13, 2012 I think everyone if their honest as at least one set back during a build. Nice choice for the finished scheme, she be a looker. Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 13, 2012 Author Share Posted April 13, 2012 Oh it's definetely friday 13th good news is I sorted out cracked joints sanded & reprimed, Then as i was spraying alclad onto model my compressor STOPS DEAD nothing worked,For an hour I turned the air blue unplugged it kicked it then decided to go to pub halfway there it p****d down, Get there left my wallet at home had to start a tab finished third pint sun came out went home looked at compressor pulled plug out of socket thought i'd check the fuse D'OH changed it YIPPEE it worked here's the result Used alclad durallium/white aluminium & dark aluminium not going to touch it anymore today. Link to comment Share on other sites More sharing options...
mick Posted April 13, 2012 Share Posted April 13, 2012 U/side looking good Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 14, 2012 Author Share Posted April 14, 2012 Got her preshaded today. She's now got xtracolour rlm76 & faa sky grey (rlm77??) all done with my xmas present Badger 100. Hope to get rest of colours on tomorow. Link to comment Share on other sites More sharing options...
tank152 Posted April 14, 2012 Share Posted April 14, 2012 Starting to look the part now, isn't just great when you first start to lay the first colours down. Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 15, 2012 Author Share Posted April 15, 2012 Hi all just got some colour on xtracolour rlm 83/75 then open there rlm81 braunviolet it was green so decided to use humbrol 133 brown. First time doing luftwaffe aircraft paint scheme. Was really pleased with result UNTIL after finished spraying I got this i dont know why if someone could give me advice on how to remedy this I would be really grateful. Got a snakeskin finish. Never had this happen before. I used cellulose thinners mixed at about 60/40 (thinners/paint) I do spray in my garage at 8-10 psi it wasn't cold outside Link to comment Share on other sites More sharing options...
Mottlemaster Posted April 15, 2012 Share Posted April 15, 2012 HI Marc What a shame with the paint but im sure it wont take long to sort out . I think your problem isn't a spray tequnice problem or air temp but a paint /paint reaction , possibly the celulose thinners not drying fast enough so it reacted with your faa sky grey . Try removeing with enamel thinners. Hope this helps Alistair Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 15, 2012 Author Share Posted April 15, 2012 HI MarcWhat a shame with the paint but im sure it wont take long to sort out . I think your problem isn't a spray tequnice problem or air temp but a paint /paint reaction , possibly the celulose thinners not drying fast enough so it reacted with your faa sky grey . Try removeing with enamel thinners. Hope this helps Alistair Thanks Alistair will give a try with isopropyl alchohol first if that don't work i'll try with thinners. Thought it was me as first time with airbrush really appreciate your response. Link to comment Share on other sites More sharing options...
tank152 Posted April 15, 2012 Share Posted April 15, 2012 It looks like you have you have put to much of a wet coat on and cellulose is a hot thinner so has burnt through the previous layer of paint or something along those lines. Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 15, 2012 Author Share Posted April 15, 2012 It looks like you have you have put to much of a wet coat on and cellulose is a hot thinner so has burnt through the previous layer of paint or something along those lines. Thanks i think your right,that's what i done only thing i can remember doing probably in my over enthusiasm NOT GOING TO DO THAT TWICE now giving it a rub down,back to work next week take my mind off my mistake!!! Link to comment Share on other sites More sharing options...
jacksdad Posted April 15, 2012 Share Posted April 15, 2012 Just when everything was back on track. That can sometimes happen when the coat below has not cured fully. Steve Link to comment Share on other sites More sharing options...
tank152 Posted April 15, 2012 Share Posted April 15, 2012 Thanks i think your right,that's what i done only thing i can remember doing probably in my over enthusiasm NOT GOING TO DO THAT TWICE now giving it a rub down,back to work next week take my mind off my mistake!!! Probably a bit late now but if I was you I wouldn't touch it at all today, let everything go off and stop reacting. I know that'll be hard to do but you may make things even worse if you don't. I know its a set back for you but it'll be fixable. Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 20, 2012 Author Share Posted April 20, 2012 Rescued it left alone for a couple of days before I rubbed down my mistake. Hope to get some markings on her this weekend. Link to comment Share on other sites More sharing options...
jacksdad Posted April 21, 2012 Share Posted April 21, 2012 Good rescue Marc. Are you on for getting it finished in time? Steve Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 21, 2012 Author Share Posted April 21, 2012 Good rescue Marc. Are you on for getting it finished in time? Steve That's the plan got two weeks to do it should get the markings on this weekend. Link to comment Share on other sites More sharing options...
Mottlemaster Posted April 21, 2012 Share Posted April 21, 2012 Agree well recoverd Link to comment Share on other sites More sharing options...
mick Posted April 21, 2012 Share Posted April 21, 2012 good work to save the camo Link to comment Share on other sites More sharing options...
Marcdb71 Posted April 22, 2012 Author Share Posted April 22, 2012 Got the spinner done used eduard spiral mask Sprayed the tail band & got decals on just stencil markings to put on. Still 2 weeks to go hope I can make it?? Link to comment Share on other sites More sharing options...
tank152 Posted April 22, 2012 Share Posted April 22, 2012 Glad you managed to save it, its a right downer when things like that happen. Well masked spinner but what is that brown on the fuselage sides? Link to comment Share on other sites More sharing options...
mick Posted April 22, 2012 Share Posted April 22, 2012 looking very good Link to comment Share on other sites More sharing options...
jacksdad Posted April 23, 2012 Share Posted April 23, 2012 Thats looking very nice indeed Marc. There's something very nice about a patch-work 190. Steve Link to comment Share on other sites More sharing options...
Marcdb71 Posted May 2, 2012 Author Share Posted May 2, 2012 Got decals on at weekend & just varnished it tonight all ancillaries ready to attach, should get it finished this weekend will post pics later when varnish dry. Link to comment Share on other sites More sharing options...
