Star Wars TESB MPC Snowspeeder
  • Please log in to reply
102 replies to this topic
#21 Neal
Neal
  • Members
  • 728 posts
Posted 10 December 2011 - 07:04 AM
Not much progress; bit more dry brushing of the rear cooler with some lighter greys and black to make the finish a bit more uneven. Then a dry brush with copper between the fins and some chipping with aluminium. Pics with and without flash.
Posted Image
Posted Image
It's not much in the overall build or compared to the standard of build on BM but I'm really pleased with it
Removed some if the heavy maskol and glued some of the minor parts together.
Edited by Neal, 10 December 2011 - 07:27 AM.
#22 mrvr6
mrvr6
    Very Obsessed Member
  • Members
  • 1,701 posts
Posted 10 December 2011 - 09:30 AM
fom here that looks like a lump of cast aluminium so id say its spot on fella :)
#23 Neal
Neal
  • Members
  • 728 posts
Posted 10 December 2011 - 12:07 PM
Thanks, just want to find the time to get on with the rest of it.
#24 Neal
Neal
  • Members
  • 728 posts
Posted 12 December 2011 - 09:31 PM
Success! Used the promodeller wash as it worked really well (no surprise to most of the more experienced modellers here I imagine) the cockpit now looks like the hastily prepped and well used fighter, I also used it on the inside of the airbrake well. Just need to fix the instrument packs and tidy up the join and the cockpits done.
Posted Image
I've also drilled out the ends of the cannons, retouched the maskol and taken the plunge and given the pilots a primer coat.
As always, comments & advice (good bad or indifferent) are always welcome.
Edited by Neal, 12 December 2011 - 10:54 PM.
#25 Neal
Neal
  • Members
  • 728 posts
Posted 16 December 2011 - 10:16 PM
Few hours work this evening. Bill and Ben the monkey pilots are done, just needs a coat of klear and a bit of dry brushing and a wash, don't know whether to use the promodeller or mix a dark red/orange.
Posted Image
Looking at this picture the red (no-one ventured an opinion on the previous post so red it is) squadron markings need to go on the underside which is something I've never noticed.
http://www.modelerma..._orange-026.jpg
Tidied up the cannon joint and rescribed some of the panel lines that I'd sanded off. Painted the lower airbrakes and rear or the craft. I've also found some old low viz markings for various warnings and stenciling (not the star and bar though) that I might use when it's all finished as the kit ones are a bit limited.
Posted Image
Need to get the final colour mixed, can't really put it off much longer.
Edited by Neal, 23 December 2011 - 07:55 AM.
#26 Neal
Neal
  • Members
  • 728 posts
Posted 19 December 2011 - 10:48 AM
I could do with a bit of advice from the BM collective; Ive not that much experience painting figures but i think Bill and Ben the monkey pilots need a coat of klear and a wash and then a lighter dry brush. For the wash I don't know whether to use the dark or mix a dark red/orange?
Edited by Neal, 19 December 2011 - 11:20 AM.
#27 cjhm
cjhm
    Established Member
  • Gold Member
  • 437 posts
Posted 19 December 2011 - 11:19 AM
I could do with a bit of advice from the BM collective, Bill and Ben the monkey pilots need a coat of klear and a wash and then a lighter dry brush. For the wash I don't know whether to use the dark or mix a dark red/orange?
All looking good so far, my vote would be a brownish\reddy wash, GW Gryphonia Sepia or MIG Neutral are what I am planning for little wedge and his chum when I get that far on the X-wing.
I see you're using the pro-modeller (not tried these), not sure if these can be re-wetted if they go on too heavy ? The GW ones are like thin acrylics and are a bugger if you get it wrong but with the MIG ones, as they are enamel a bit of thinner lets you start again easily.
#28 Neal
Neal
  • Members
  • 728 posts
Posted 19 December 2011 - 11:25 AM
First time I've used the promodeller wash, I think that they can be removed by rewetting and a bit of a scrub, assuming that it's over a varnish/klear.
I'll give them a couple of coats of klear then probably make my own dark red wash with some thinned down acrylics and washing up liquid.
Edited by Neal, 19 December 2011 - 05:22 PM.
#29 Jasonb13
Jasonb13
    'Looks good from a distance' modelling
  • Gold Member
  • 808 posts
Posted 19 December 2011 - 11:05 PM
Yep, Promodeller can be re-wetted and removed, the more of a gloss coat on the plastic before the wash, the easier it is to remove it. That said, even on a matt coat I've been able to remove a Promodeller wash when needed!
J.
#30 The Velociweiler
The Velociweiler
    Obsessed Member
  • Members
  • 663 posts
Posted 20 December 2011 - 09:44 AM
I'd agree with you about the red - I've seen models in both plain and with the red banding and those with the red stand out better - the plain ones just don't look right for some reason.
#31 Neal
Neal
  • Members
  • 728 posts
Posted 21 December 2011 - 04:16 PM
Need to get the present wrapping done then I can get on with this....
There are only a few big jobs left, final paint colour, button it all up, paint the red markings, weather it. In reality whenever I think about the next big job I come up with a bucket load of minor jobs that need doing on the way (mask this, klear that, glue the other) I need to make a list otherwise I'll be missing things or getting them in the wrong order.
Edited by Neal, 21 December 2011 - 04:33 PM.
#32 Neal
Neal
  • Members
  • 728 posts
Posted 21 December 2011 - 11:19 PM
Well after 2 hours of unsuccessfully battling to fix the PC (thank God for the iPhone) I thought I'd have 10 minutes doing something that I can actually understand and have an affect on. Put some dark weathering scuffs on the helmets (the red band was already pre-chipped with maskol, and cave them a coat of klear, another coat tomorrow and then I can add a wash.
Posted Image
Not a lot, but very therapeutic.
#33 The Velociweiler
The Velociweiler
    Obsessed Member
  • Members
  • 663 posts
Posted 22 December 2011 - 08:53 AM
I built this one in 1990 and tried to replace the Pilots with those from a Fujimi racing driver set. The Snowspeeder cockpt had absolutely zero leg room so I ended up cutting off the pilots legs high at the thigh and still had to lean them back heavily so's the lid could clamp down properly. Unfortunately, the original pattern maker in 1980 (the kit first appeared at the toyfairs in early 1981) realised very early on that to add pilots to the model, they'd have to have fairly odd shapes to fit the kit. I think there were some reasonable looking resincast replacements available from the USA around fifteen years ago, but they were expensive, and weren't around for long...
However, once the kit figures are dun'n'dusted and are placed into the cockpit, they really don't look too bad.
#34 Neal
Neal
  • Members
  • 728 posts
Posted 22 December 2011 - 04:19 PM
"However, once the kit figures are dun'n'dusted and are placed into the cockpit, they really don't look too bad."
They do have a certain retro charm as well...
Edited by Neal, 22 December 2011 - 04:20 PM.
#35 Neal
Neal
  • Members
  • 728 posts
Posted 22 December 2011 - 11:01 PM
Used the promodeller dark wash on the helmets and white parachute (?) made dark red wash for the orange, used white with a touch of orange to dry brush the suit. Unturned Pringles lids were ideal for mixing this little lot on.....
Posted Image
And all in the office. The pilots arms are a bit long (should've done more dry fitting) so they needed removing and lifting up.
Posted Image
Not a good as Dan's Viper cockpit, but I'm pleased with it.
http://www.britmodel...showtopic=78877
Edited by Neal, 23 December 2011 - 12:21 PM.
#36 Neal
Neal
  • Members
  • 728 posts
Posted 23 December 2011 - 10:43 PM
Finally mixed the top colour and gave everything a first coat, there's a surprising amount to do and took ages with the brush. The mix was 40% XF-2, 40% XF-80, 20% XF-55. Looked a bit creamy initially but seems to be drying a bit lighter. Typically I don't think I've mixed enough for the second coat so might go a bit lighter & greyer with the next batch.
Posted Image
Doesn't actually look that different from when I started.
I think that'll be it for anymore progress before the new year, Merry Christmas and thanks for looking
Edited by Neal, 24 December 2011 - 03:10 PM.
#37 Neal
Neal
  • Members
  • 728 posts
Posted 27 December 2011 - 10:52 PM
I was thinking about some of the weathering once all the painting is complete; for the blast damage I'm going to dry brush most of it but without an airbrush I may need to use some pastels or some of those Tamiya weathering kits for AFV's, any opinions or direction from the BM collective brain?
Edited by Neal, 27 December 2011 - 10:53 PM.
#38 The Velociweiler
The Velociweiler
    Obsessed Member
  • Members
  • 663 posts
Posted 27 December 2011 - 11:21 PM
Frequently the studio originals were simply spraycan blasted with paint since there was a severe time pressure on their completion. During ESB and the earlier film, there was only limited airbrushing generally applied for exhaust streaks etc. A glance at the photos of the originals shows one technique they used fairly often. Use your Tamiya pastels to smudge a larger area with a dark burn, and then either with very thin card or even tape, scab a pale painted panel over the smudge, leaving a 'repaired' section over the damaged paintwork. With other coloured panelled areas, you may wish to leave some irregular swabs of Humbrol maskol on the first coat prior to painting a second colour over (for example the darker greys or the red areas of the Snowspeeder). Once the upper colours are fully dry, pick the maskol masking solution out leaving a damaged section of the paintwork. Naturally, don't be scared to pick at the paint irregularly with the tip of a scalpel blade, scoring and scratching areas which would be lifted by maintenance or rearming teams.
#39 Neal
Neal
  • Members
  • 728 posts
Posted 28 December 2011 - 09:49 PM
Thanks for the advice it helps at lot, as I've said before the whole weathering frankly scares me, I'm sure it'll be ok when I get going but still.....
#40 Neal
Neal
  • Members
  • 728 posts
Posted 31 December 2011 - 06:42 PM
Tamiya snow, soot & rust weathering set ordered.
I think the rust will be useful as I imagine the weather on Hoth is not too kind to ferrous metals (assuming there's some iron in a galaxy far far away)
Will they be ok to be brushed over with klear or will they smear everywhere?
Hoping to get some modelling done over the next couple of nights.
