desmojen Posted August 20, 2008 Share Posted August 20, 2008 Here's my build thread. The main official unofficial entry is this Fujimi 1/48 Mitsubishi F-1. I got it for £5 (!) at the Avon show. If the guy I bought it off see's this....thanks! This will be pretty much OOB, I might spruce the cockpit up a bit, or I might not It will be in markings as per box art though. The other build I would like to post updates on, but not necessarily officially enter is this, Hasegawa 1/48 F-15DJ. This is a limited boxing that I got from HLJ. Now, I know it's half done, but so far it has taken about a year and a half On that basis, the likelihood of it getting finished in the next 90 days is quite slim! Jen. Link to comment Share on other sites More sharing options...
AnonymousER99 Posted August 20, 2008 Share Posted August 20, 2008 The Fujimi F-1 is actually one of their better kits from back in the day...a bit simple in the cockpit but shape is ok. Get that Eagle done Jen!! What paint are you planning for it? Mike Link to comment Share on other sites More sharing options...
Nev Posted August 20, 2008 Share Posted August 20, 2008 Yep, interested to see what you're doing with the DJ. Have you got the proper burner cans for it? Link to comment Share on other sites More sharing options...
desmojen Posted August 20, 2008 Author Share Posted August 20, 2008 (edited) Yep, interested to see what you're doing with the DJ. Have you got the proper burner cans for it? It's this kit. Nice scheme huh? It will look sweet with my already made dragon one As for burner cans, er, I have the ones in the kit..... Jen. Edited August 20, 2008 by desmojen Link to comment Share on other sites More sharing options...
Nev Posted August 20, 2008 Share Posted August 20, 2008 Personally, I've always found that scheme a little gaudy As for the burner cans - early F-15s had them covered with "Turkey Feathers" (struggling to find a decent pic, this is the Aries set) But then they were removed (mid 80s?) to save weight and ease maintainence The 1/48 kit comes with the early version - although I have heard that there are boxings with the proper set. 1/72 kit comes with late version. Aries do a very nice set http://www.hannants.co.uk/search/?FULL=AIRE4336 Your bird has these later ones btw if you want more pics, let me know, I've got about a dozen of this particular F-15. Link to comment Share on other sites More sharing options...
desmojen Posted August 20, 2008 Author Share Posted August 20, 2008 In that case I have the right ones. My kit actually has both types in it, but I've made the plucked ones. Gaudy?? I suppose it is a bit bright... Jen. Link to comment Share on other sites More sharing options...
Mentalguru Posted August 20, 2008 Share Posted August 20, 2008 Gaudy- GAUDY!!!! Jen- it's perfect- couldn't htink of anything better- except possibly a Tamiya DJ to put it on rather than that abomination of a Frankenkit yo are working on. Link to comment Share on other sites More sharing options...
AnonymousER99 Posted August 20, 2008 Share Posted August 20, 2008 As an aside on Hasegawa 1/48 Eagles, the only kits that still have the feathered cans are the P series kits like P10, the first Strike Eagle kit, the firs J and B/D kits as well. ALL of the newer releases have both sets of cans in them. I own EVERY Hasegawa Eagle kit boxing and can verify if you have any questions. Also, if anyone needs info on Eagles I spent a LOT of time around them. Cheers Mike PS Jen, I cant wait to see your FUGLY one built up!! Link to comment Share on other sites More sharing options...
Nev Posted August 21, 2008 Share Posted August 21, 2008 I own EVERY Hasegawa Eagle kit boxing and can verify if you have any questions. Bloody hell Mike, thats a lot of Eagles!! And a lot of $$$$$$$$$$$$$... Link to comment Share on other sites More sharing options...
AnonymousER99 Posted August 21, 2008 Share Posted August 21, 2008 Bloody hell Mike, thats a lot of Eagles!! And a lot of $$$$$$$$$$$$$... All collected and traded for over time so the sting wasnt so bad Link to comment Share on other sites More sharing options...
desmojen Posted August 24, 2008 Author Share Posted August 24, 2008 I have made a tentative start on the Mitsi. I chopped off the cockpit parts and sat them on the table, somewhat in horror at how, er, detailed they are! I was considering jazzing it up a bit, but faced with the magnitude of the task I started scanning around for alternatives. The seat is sorted via our very kind host, Mr Mike Reeves, thankyou Mike I then went scrabbling through my jet spares box for some ideas on the tub and IP. I stumbled across a spare two seat tub from the Academy kit that I used for my Shiro Ryu build (the Academy kit has options for both single and twin seat jets in the kit) About ten minutes later, after some snipping and taping, I had this! Pretty cool huh! Ok, I know it's not an F-1 cockpit, but who's going to know? I won't tell if you don't Jen. Link to comment Share on other sites More sharing options...
desmojen Posted September 1, 2008 Author Share Posted September 1, 2008 (edited) Bit more on this, I now have the fuselage together, filled and sanded. The fit was basically very sound, most of the problems I did have being down to me not watching where I was holding it when the glue was setting! The supermassivegreatbig fin is fitted too. It had a small gap along the bottom but that was easily sorted. The new cockpit tub was extended upwards at the back and then a parcel shelf made from plastic card was added. I also extended the coaming past the top of the dashboard and made a pretend HUD to sit on it. It's lower than I would have liked but that is necessary to allow it to clear the windscreen (I actually remembered to check!) You can also see the new stick in the top picture, it's robbed from an F-18 kit and extended to suit with a bit of plastic rod. The new seat which is much, much, much, much better than the original is just placed in the cockpit for effect right now I'll take a closer pic of the cockpit in the daylight tomorrow, the flash just over exposed everything Jen. Edited September 1, 2008 by desmojen Link to comment Share on other sites More sharing options...
desmojen Posted September 7, 2008 Author Share Posted September 7, 2008 (edited) Marching on with this, I now have the main construction essentially done. No real problems to report, I trimmed the wings a little to get smaller gaps. The intakes are a good example of how to do it right, Italeri and Airfix take note! I had a bit of rescribing to do on the wings which I did before I fitted them because a lot of the panel lines on this kit are raised. I basically rescribed the ones I knew would get damaged and left the rest alone. The undercarriage is one of the fiddliest things I've ever seen, which is why I fitted it all before paint, using plastic cement for strength. I seriously doubt that superglued painted joints would hold up. I will bang a coat of Mr Base White on there tomorrow to see how much more work I need to do on the seams. I'm not too sure on the underside colour either because the instructions say it is H316 (White) in one place and H57 (Grey) in another Does anyone know which it should be? Jen. Edited September 7, 2008 by desmojen Link to comment Share on other sites More sharing options...
Takamota Posted September 7, 2008 Share Posted September 7, 2008 Starting to zip along now Jen... Looks goos to me. Link to comment Share on other sites More sharing options...
Oliver Posted September 7, 2008 Share Posted September 7, 2008 Looking good now Jen. The underside colour is a light grey, here's a link with some walkaround photos that should help you: http://www.midwaysailor.com/photos/mitsubishi-f1.html Link to comment Share on other sites More sharing options...
desmojen Posted September 12, 2008 Author Share Posted September 12, 2008 Double update today! First off, progress on the Mitsi. As you can see, all primed. I've used Mr Base White for the initial primer coat. I have now rubbed it down where necessary and fitted a HUD glass and the windscreen. The fit of the windscreen is less than grand, but a whole lot better than the fit of the main canopy which is absolutely horrendous! I didn't want the canopy open, not least becuase the interior detail isn't great. Seeing this though makes me think I might have to Progress on the F-15 is slightly more gladdening. I sprayed the two tone greys where necessary using Gunze acrylic H307 and 308 as detailed in the instructions. I then set about masking up for the black and white areas. It was at about this point that I was glad I bought several rolls of Tamiya tape for £1 each from HLJ last time! In these photos the white is already on and I have masked for the black. Almost all of this is actually on the decal sheet but you do have to paint some of it. I thought it might be easier and give a more consistent result if I just painted all of it. Took a really long time to mask it all though and some of it was a bit tricky I'm leaving that to set up nicely before a couple of coats of Klear to seal it all together ready for some decalling. Of course, there is a ton of other stuff that will need painting up as well like tailfins and tailplanes, main canopy, pylons, fuel tanks - all sorts! Jen. Link to comment Share on other sites More sharing options...
AnonymousFY21 Posted September 12, 2008 Share Posted September 12, 2008 Looks good, love the 15. Better get on with mine. You going to have them at Telford? rich Link to comment Share on other sites More sharing options...
Nev Posted September 12, 2008 Share Posted September 12, 2008 All that masking - eek! Looking good though, and I would definately go with the open canopy on the F-1 Link to comment Share on other sites More sharing options...
Guest snipersmudge Posted September 12, 2008 Share Posted September 12, 2008 super masking job on the eagle Jen very tidy Link to comment Share on other sites More sharing options...
AnonymousER99 Posted September 12, 2008 Share Posted September 12, 2008 Jen Both builds look smashing!! As far as the underside of the Mitsubishi, the decals I am about to send to Smudge made by Platz in Japan call out for Light Gull Grey underneath, Gunze H325 to be precise. Mike PS, I will hae more pics of mine posted over the weekend. Link to comment Share on other sites More sharing options...
Stebos Posted September 12, 2008 Share Posted September 12, 2008 That F-15 is looking very special indeed! Can't wait to see it done. Link to comment Share on other sites More sharing options...
dswoofie Posted September 12, 2008 Share Posted September 12, 2008 Nice!! That F-15 is going to look too coool, especially with the all paint job and not decals Better get me some specifications for this F-15 base then! Karl. Link to comment Share on other sites More sharing options...
dahut Posted September 12, 2008 Share Posted September 12, 2008 I think they look dangly. Gaudy is good, in it's place. But I have question: Can you say "Jap?" I've gotten hell for it before. One must be PC, you know... Link to comment Share on other sites More sharing options...
Nev Posted September 15, 2008 Share Posted September 15, 2008 Not in America, but it doesn't have the same racial connotations over here. Its like how you can say "Paki" in Australia, but not in Britain Link to comment Share on other sites More sharing options...
dylan the rabbit Posted September 15, 2008 Share Posted September 15, 2008 Not in America, but it doesn't have the same racial connotations over here. Its like how you can say "Paki" in Australia, but not in Britain I guess Americans don't say "It's a bit Pearl Harbour isn't it?" when it's cold then? Link to comment Share on other sites More sharing options...
