Maxidad Posted July 13, 2008 Share Posted July 13, 2008 (edited) I have just started Revell's 1/72 Ju88 A4/D1. OK I know this is an old kit and although I am not a modeller who demands absolute realistic accuracy, I simply have to rescribe this kit. I just put fuselage halves together and once I sand the seams, I just know the raised panel lines are gonna disappear top and bottom. So my scrounge is this: where can I get some diagram of the panel lines for this a/c? Edited July 13, 2008 by Maxidad Link to comment Share on other sites More sharing options...
Deanflyer Posted July 13, 2008 Share Posted July 13, 2008 (edited) Try this: http://airwar.ru/other/draw_aw.html It's all in russian, but then scroll down to the Ju-88 section and there are various drawings to download as zip files. Should be something there of use to you. Hope that helps, Dean Edited July 13, 2008 by Deanflyer Link to comment Share on other sites More sharing options...
Maxidad Posted July 14, 2008 Author Share Posted July 14, 2008 Try this:http://airwar.ru/other/draw_aw.html It's all in russian, but then scroll down to the Ju-88 section and there are various drawings to download as zip files. Should be something there of use to you. Hope that helps, Dean Hi there. Thanks for this, but are you sure the link / url is working. I amn not having much luck. Link to comment Share on other sites More sharing options...
PetrOs Posted July 14, 2008 Share Posted July 14, 2008 http://airwar.ru/other/draw/ju88sch.htmlHi there. Thanks for this, but are you sure the link / url is working. I amn not having much luck. Hello I was also going to suggest you the airwar site. The link is working for me fine. But, Ill get you the direct links to the plans: http://airwar.ru/other/draw/ju88.html http://airwar.ru/other/draw/ju881.html http://airwar.ru/other/draw/ju882.html http://airwar.ru/other/draw/ju88sch.html http://airwar.ru/other/draw/ju88kr.html Link to comment Share on other sites More sharing options...
Maxidad Posted July 14, 2008 Author Share Posted July 14, 2008 HelloI was also going to suggest you the airwar site. The link is working for me fine. But, Ill get you the direct links to the plans: http://airwar.ru/other/draw/ju88.html http://airwar.ru/other/draw/ju881.html http://airwar.ru/other/draw/ju882.html http://airwar.ru/other/draw/ju88sch.html http://airwar.ru/other/draw/ju88kr.html Thanks to both of you. I am gonna have my work cut out! Link to comment Share on other sites More sharing options...
