dylan the rabbit Posted July 6, 2008 Share Posted July 6, 2008 Based on the great thread in the WW2 section, I though I'd start a proper WIP thread on the build of the Hurricane of the Battle comic book fighter pilot ace, Johnny Red. http://www.falconsquadron.sevenpennynightm...y/1977/1977.htm The plane should ideally be a Sea Hurricane, but the comic book really shows it off as a plain, bog standard Mk.1 Hurricane in dark earth/dark green/sky colours, so I'm going to be faithful to that and not nitpick. I'm using the 1/72nd Revell Hurricane Mk.II kit, which I originally planned to build for the SEAC GB, but failed miserably on! Here's where she is now: As Johnny's crate is a Mk. I, I've decided to make a rod for my own back by converting the wings from a Mk.II, i.e, fill in all the panel lines and access panels for the canons, ammo, shell ejector holes on the underside, and rescribe them as if they were for the Brownings. I'll post a shot of that later. Cheers, Nick Link to comment Share on other sites More sharing options...
dylan the rabbit Posted July 6, 2008 Author Share Posted July 6, 2008 Here's the wings slathered in my goo... Sprue and glue goo of course.. Will get round to sanding this down, along with the canon bulges tomorrow when the glue's set, then, on to the rescribing.. Nick Link to comment Share on other sites More sharing options...
dylan the rabbit Posted May 23, 2009 Author Share Posted May 23, 2009 Almost a year later, I'm back at it! The wings are ready to be scribed.... More to follow! Nick Link to comment Share on other sites More sharing options...
dylan the rabbit Posted May 24, 2009 Author Share Posted May 24, 2009 Right. The decals worked well. Scanned plans from the SAM publications book, printed on decal paper, set with Microscale, and then overlayed on the wings, using the outer panel lines (which I didn't fill in) as a reference. Looks alright I think. I'll get to work scribing along the decals later on once they're fully dry. (For all of you asking WHY?.. It was use this one, or rescribe the Mk1 Airfix... Less ballache on this one!) Cheers, Nick Link to comment Share on other sites More sharing options...
KLP Publishing Posted May 24, 2009 Share Posted May 24, 2009 Hang on Nick, you've lost me - are you saying the entire wing is covered by a giant decal, containing roundels and panel detail? Kev Link to comment Share on other sites More sharing options...
dylan the rabbit Posted May 24, 2009 Author Share Posted May 24, 2009 Hang on Nick, you've lost me - are you saying the entire wing is covered by a giant decal, containing roundels and panel detail? Kev Yup.. Link to comment Share on other sites More sharing options...
dylan the rabbit Posted May 24, 2009 Author Share Posted May 24, 2009 (edited) Ok, as my first attempt at rescribing this way (using decals as a template), I learnt that you have to scribe with a new blade in order to slice through the decal and score the plastic. I made a few mistakes, especially when I tried to cut time and freehand along the lines of the decals (yuk). There are a few cock ups, but nothing that can't be corrected, although when I first took a look at it, I was going to bin it and rescribe the Airfix kit. Waste of a kit I thought you daft pillock, so on we go.. Machine gun holes were first marked out in pencil, and the holes were made with a hot needle. It's NOT perfect, but hey? Vot to do? It's being made honouring a cartoon character! A bit of tart up, and she's ready for spraying (after I mask the canopy first.. Bleuuuugggghhhhhh). Cheers, Nick Edited May 24, 2009 by dylan the rabbit Link to comment Share on other sites More sharing options...
General Buck Turgidson Posted May 24, 2009 Share Posted May 24, 2009 Ok, as my first attempt at rescribing this way (using decals as a template), I learnt that you have to scribe with a new blade in order to slice through the decal and score the plastic. I made a few mistakes, especially when I tried to cut time and freehand along the lines of the decals (yuk). There are a few cock ups, but nothing that can't be corrected, although when I first took a look at it, I was going to bin it and rescribe the Airfix kit. Now that is what I call innovation. I wish I had the kit (and brilliance) to try something like that! Re the panel lines – try an old No.11 with a very slightly broken tip used in the reverse if that makes any sense. Drag it along the intended panel line towards yourself at an ever so slight angle. With practice you should be able to remove a fine curl of plastic and leave behind a neatly finished panel line. I hope this helps! Link to comment Share on other sites More sharing options...
dylan the rabbit Posted June 25, 2009 Author Share Posted June 25, 2009 Not much to show you at the moment, apart from the undersides are now painted sky, and there's a sky band around the fuselage. Now, onto masking the canopies. Hates it we does.. Link to comment Share on other sites More sharing options...
Heraldcoupe Posted June 26, 2009 Share Posted June 26, 2009 Now, onto masking the canopies. Hates it we does.. Tell me about it... Revell Lancaster.... mutter......... Cheers, Bill. Link to comment Share on other sites More sharing options...
dylan the rabbit Posted June 28, 2009 Author Share Posted June 28, 2009 In the end I used blu tack on some of the smaller squares, and straightened it up as much as possible with a cocktail stick. Masking windows with tape in 1/72nd? Life's too short! Spraying started this evening, with the first coat of Xtracolour Dark Earth. Despite the heat of the evening here, it performed fantastically. I do love that paint. Cheers, Nick Link to comment Share on other sites More sharing options...
dylan the rabbit Posted July 9, 2009 Author Share Posted July 9, 2009 With Xtracolour Dark Earth on... Quite like how that wing conversion turned out... Onto the masking for the green next week. Cheers, Nick Link to comment Share on other sites More sharing options...
dylan the rabbit Posted July 25, 2009 Author Share Posted July 25, 2009 Still not masked yet! Anyway, here's a shot with the Hasegawa spinner on instead of the Revell one. Much better. Masking and green in a day or so. Cheers, Nick Link to comment Share on other sites More sharing options...
dylan the rabbit Posted September 3, 2009 Author Share Posted September 3, 2009 Masking off, Klear coat to be done on the undersides, and then I spray on the red falcon! Cheers, Nick Link to comment Share on other sites More sharing options...
dylan the rabbit Posted September 6, 2009 Author Share Posted September 6, 2009 Ok, so here goes with the masking for the falcons. The masks were made by Nenad at Aeropoxy in Yugoslavia. Top bloke, and he made the vinyl masks for the falcons based on the cartoon sketches and CGI off a flying game I sent him. You can see the mask surrounded by the Tamiya tape to prevent overspray. I used Revell carmine red, which I like as it's a nice dirty shade of red. Masks off.. Nenad made a decal of a black outline to go around the red spray, and I also have to do a little painting for the beak and claws, but it's pretty damm good. I had to go over the kit with a cotton wool bud dipped in white spirit, as I had a little more overspray than planned (a lesson for the next build using his masks). I like! Cheers, Nick Link to comment Share on other sites More sharing options...
Antony Robertson Posted September 6, 2009 Share Posted September 6, 2009 That looks great, and then idea of using the decals to mark out the panel lines for scribing is brilliant!! Were you tempted to leave the wings smooth and just use the decal instead? Link to comment Share on other sites More sharing options...
dylan the rabbit Posted September 6, 2009 Author Share Posted September 6, 2009 That looks great, and then idea of using the decals to mark out the panel lines for scribing is brilliant!! Were you tempted to leave the wings smooth and just use the decal instead? Nah. What would I put my panel wash into? Link to comment Share on other sites More sharing options...
Johnny Red Posted September 6, 2009 Share Posted September 6, 2009 Hi Dylan how are things just got the email and read all that you’ve been doing , the Hurricanes looking great , how much did the masks for cost? If you don’t mind me asking. Link to comment Share on other sites More sharing options...
Heraldcoupe Posted September 6, 2009 Share Posted September 6, 2009 That's really neat! The masks are a great idea, I did my Falcons for the red bird by printing onto white decal paper, your solution's a lot neater. Didn't help that I sealed my decals with Klear, then used an Ammonia based setting solution on them..... Cheers, Bill. Link to comment Share on other sites More sharing options...
AnonymousFO98 Posted September 6, 2009 Share Posted September 6, 2009 Tip top Nick looking very good Link to comment Share on other sites More sharing options...
dylan the rabbit Posted September 8, 2009 Author Share Posted September 8, 2009 Thanks chaps. Here she is with decals.. The mask maker gave me a set of decals of the eagle outline in black, to go around the spray of the decal. Would have added a nice contrast to it and made it "pop" off the plane. However, I kakked that up pulling the mask out of it's surrounding vinyl, so the shapes weren't the same. Anyway, it's a comic book plane, so I'm not going to get anal about it. Undersides and undercarraige tomorrow. Cheers, Nick Link to comment Share on other sites More sharing options...
Alan P Posted September 8, 2009 Share Posted September 8, 2009 (edited) Anyway, it's a comic book plane, so I'm not going to get anal about it. If only everyone was that forgiving! (Well i am at any rate!) I hope you are going to finish it in a nice bullet-spitting diorama with a spiky voice balloon by the cockpit saying "Die Fritz!" Al PS like this! Edited September 8, 2009 by PHaTNesS Link to comment Share on other sites More sharing options...
Angels49 Posted September 9, 2009 Share Posted September 9, 2009 JR.....your modeling skills are again on display and I wish I had in my whole body what you have in just one of your hands....great work mate. Link to comment Share on other sites More sharing options...
dylan the rabbit Posted September 13, 2009 Author Share Posted September 13, 2009 (edited) Cheers Clif and Al.. May well try and get a shot in a comic book setting.. Eat lead! Here's the latest.. Still need to gloss the prop, put decals on it and yellow tips, spray the red for the gun port doping, add the beak and claws for the falcons, add the exhausts, and once that's done, weather it.. Tata, Nick Edited September 13, 2009 by dylan the rabbit Link to comment Share on other sites More sharing options...
dylan the rabbit Posted September 16, 2009 Author Share Posted September 16, 2009 Final bits done, and she'll be getting a matt coat today (hence the blu-tack over the landing lights). Cheers, Nick Link to comment Share on other sites More sharing options...
