neilfgr2 Posted May 5, 2007 Share Posted May 5, 2007 got the Academy 32nd F-16 . What is the difference between a block 30 and a block 40 Falcon??? What do I need to change??? Cheers, Neil Link to comment Share on other sites More sharing options...
spike7451 Posted May 5, 2007 Share Posted May 5, 2007 OOhhh Sorry,We dont do *-**'s here... You need to change it to a Tornado G1 in 17f Sqn markings (The BEST Tornado Sqn in the RAF BAR none!!) (Sorry,too much Whisky) Link to comment Share on other sites More sharing options...
Bandwagon 106 Posted May 5, 2007 Share Posted May 5, 2007 Talk about nice timing, I've just started mine Neil! I'm doing a block 40 from the 23rd FW, The Flying Tigers! The -C-30 has a standard HUD unit, provided in the kit, lighter weight landing gear, (not in kit), no strengtheners on the fuselage, non bulged MLG doors and landing lights on the MLG, not the nose gear door. The wheels are also less bulky and have a different pattern. Current block 30s use either Litening or Sniper pods, and I'm not sure if they have upgraded the landing gear. Check the serial number, as it might use either the big mouth or standard inlet (MCID or NSI), either way,you can use the kit intakes. Hasegawa do a fairly nice C-30 which has the standard landing gear. I won't be building mine now. PM me if you would like the wheel bits Joel Link to comment Share on other sites More sharing options...
